E38 Anchor Roller
tdtrimmer
I am planning on replacing the short anchor roller on the bow of my 1981 E38. The current roller is a casting and inadequate for storing an anchor. I would appreciate any thoughts and pictures of anyone who has taken on a similar project. Any idea where Ericson purchased their bow rollers? A later model one would probably do the trick.
Tom
Brisdon
Inactive Member
When you replace the bow roller, the choice you make depends more on the anchor than the boat. Go to a good chandlery and tell them what kind of anchor you have (and weight) and they should be able to outfit you with the right choice. The West Marine catalogue has a chart for which roller to use with which anchor. Good luck
tdtrimmer
I Looked at the commercially available bow rollers and determined that they are not suitable because of the configuration of the bow of the Ericson and limited space. I decided to fabricate one using 1/4 inch stainless plate. I designed one which will accomodate a CQR, Danforth or Burce. The base plate is shaped such that it provides a strong base for the roller and covers the many holes from the previous unit. I moved the running lights to the bow rail. I'll post pictures when I get it finished.
