Odelay
I ended up up just getting new plates made out of stainless
had the machine shop inspect my Ubolts and Rods(my rods are aluminum)
i feel confident that this will last another 30 years I will just add inspection of Ubolts to my yearly list.
I tried sourcing new Ubolts and it was extremely difficult and expensive to find. I was about to just have the machine shop fabricated them for me but decided against it.
We pulled the shroud chainplates yesterday. The look reasonably good except the aluminum plates. At a minimum I will replace the aluminum plates, and plan on replacing the U bolts. But the rods are the same diameter as the threaded portion of the u bolts, and made of stainless steel, so they are subject to the same stresses and work hardening as the U bolts. So I would think they should be replaced along with the U bolts. But duplicating the formed ends would be very difficult. Why not increase the depth of the aluminum plate, tap it and use a left hand thread (leaving some open threads to account for adjustment)? The new rod would then act as a turnbuckle. The bottom of the stainless rod threads into a one inch aluminum cylinder already. I can't see why this would be any less strong and adjustable as the current set up, and a lot easier to manufacture. If titanium were used this would be the last time this would ever be done. Or I could use stainless and it would probably last another 30 years.
Thoughts? Concerns? Issues I haven't considered?
Thanks!
Doug
