Afrakes
Salvaged U bolts
Hopefully that technique will work on yours. I tried the same on my 81' 28+ project and had no success. In the end the project was scrapped. After cutting the U bolts and aluminum blocks out of the deck I tried pressing them out. That eventually worked but not at all easily. The bolts survived unscathed but the aluminum blocks I found were corroded beyond further use. Of course the 28+ was a basket case. A long neglected boat with enough boat problems to fill a maintenance encyclopedia. Hope you have better luck.
Be sure to report back when you've got the rig all put back together. It should all be very straightforward now.
