I am wondering if other E38's have the same issues mine has regarding the toerail scuppers. Simply put, they are not in the best location!
On my E38 there is a scupper/drain at the aft-most section of the toerail and one about midships. The boat "lies" in the water, loaded or otherwise such that rainwater, ice, etc. all just pool up between these two drains. The worrisome thing is several stanchion bases are immersed when this happens.
I don't see an easy solution to this issue. Modifying the toerail would require removing the track bolted to to it. I have though of taking a holesaw to the rail, at deck height and then epoxying a fiberglass tube into the hole to reseal the core/interior of the rail. Just one on each side, even just 3/4" would do the trick.
Any thoughts on this?
RT
RT
