Hi Mark,
I've obviously been discussing all of this with all of this at Electric Yacht (Mike). a lot of our discussion revolved around being on Lake Erie as opposed to you guys on the ocean. Our waves are closer together than ocean waves and when the wind comes up a little, we have somewhat more chop than you might see. So with that in mind, and coupled with the fact that the weight or displacement and length of our boats are right at the upper end of their recommendation for the QuietTorque 5, I am going with the 10.Half way in between would be ideal, but they don't have that. So I guess I will err slightly higher than I need, rather than be just where I need to be or slightly less.
Likewise with the prop, I like the idea of a more aggressive prop for efficiency if I need to power along for awhile or any distance, but (if my knowledge of props and pitch is correct) I might need to compromise and be a little less aggressive pitch-wise to power through some of the chop we get here. The guys at Electric Yacht are now recommending somewhere along the lines of a 12x10 three blade, but are looking at it a little more closely so not 100% sure yet. BTW. They have been more than helpful at Electric Yacht. For that matter, all the vendors that I have spoken with have been great.
Not ready yet to go Lithium on the batteries. So right now I plan to go with 4 Mastervolt AGM's. the Slim Line 185's, which are now confirmed to be 200AH. If you haven't seen them, they are about 22" long, 5" wide, and 11 inches high, so it looks like I may be able to fit 2 of them in the old engine compartment with the motor.
That's the plan for now, while always open to more thoughts and discussion.
Thanks.
Bob
Makele
