While working on my Atomic 4, I noticed the head of one of the bolts holding the motor mount to the hull was angled. My first thought was the bolt was bent. When I removed to investigate, I found that the bolt is a 3" lag screw with most of the threads corroded off. I bought a new bolt of the same size and tried it. I cannot get it to tighten, the hull threads must be stripped. A larger bolt will not fix in the metal motor mount.
My questions are: How are the engine mounts constructed? Are they blocks of wood that were fiberglassed in place? What are recommended fixes? Someone suggested filling the hole with epoxy and fiberglass strand and re-drilling the hole. Would the fiberglass be too brittle?
thanks,
Dave
thanks,
Dave
