TheFletchers
So I recently bought an E27 that needs quite a bit of work. The worst of it is the Compression Post and aft most bulk head. The one between the head and salon that's attached to the Compression Post. The bottom of the Compression Post has become soft from sitting in water. There are a few leaks that I'll be fixing but I'm not to worried about that. What I'm worried about is getting the post out and back in as well as finding or building a replacement.
Does anyone have any experience with this? If so, I could any advise I can get. More specifically-
Do I have to remove the mast? Where is the best place to buy a piece of sollid wood for the post or can you buy a post already made?
-Sean
-Sean
