    EY.o March Zoom Meeting
Ericson 30+ Design Change 1984
Mark,
When you get a chance & if you can get to it, measure the height of the forward side of the tank where the fuel PU is located(deepest portion). I had found some old drawings supplied by another owner that showed the tank at 11.75" tall but when I measured mine it was 13.75" and obviously was not coming out the lazarette now. It could just be a tank capacity purchase option and if yours is the shorter we'll know for sure. Maybe that's why my plywood board seems to be narrower ? Don't think my gauge is accurate either but when I pumped out all the fuel last week I got close to 23 gallons. There was about 1 1/2" of air on top when I started so close to 25 g for sure. All that said I am going to try and repair tank in place. I have another post regarding fuel tank issue and probably post process there when I start in spring.
Hi Dave,
I continue to be interested in this thread, and it's complexity. I think we agreed earlier that my hull #637 was built in Oct. 1984, so after the change you reference. But I am almost sure that I have the 25 gal fuel tank rather than the 19 gal that you think comes in the later models. So I think we all need to be cautious to not assume that either earlier or later is consistently different in all aspects--it might have depended a bit on what supplies were still available in the Ericson inventory as they were making the change, though likely any change affecting the hull/deck mould would be consistent, I would think.
Dave G.
1984 E30+ (SOLD)
Frank,
I agree and think fuel tank size very well could just be a purchase option. That is why I was hoping Mark could check and if his is shorter we'll know that is not a date specific change and just a purchase point option. It would also be great if you could measure yours if possible. It could be your tank is shorter but longer or wider to fit the liner/floor on your boat but still hold 25 gal ?
Frank,
Hi Dave,
I got to the boat today. My fuel tank is almost totally covered by the floor board, so the only measurements I could get, laying on my side, were the height at the front V to top of tank is about 12 1/4" and the width across the top is about 24", but neither top corner is visible so I could only do it by feel with the tape, so it might be slightly off.
Dave G.
1984 E30+ (SOLD)
Hi Dave,
Hey Frank,
So I think your tank is the one in the drawing I found that supposedly came from the company that built the tanks for EY. But possible yours has other differing dimensions to increase capacity. Attached is the drawing I posted previously, are you positive you have a 25 gallon tank ?
  • E30_Tank_Drawing_1.pdf
Hey Frank,
Hi Dave,
This is an interesting puzzle! I looked at the original bill of sale for my boat from 1984 (previous owner) and it listed a long list of options--extra water tank, larger winches, curtains, extra lifelines, etc., but an optional fuel tank was not listed, so I think my boat (and likely others) were built with a factory choice size tank.
I note in the drawing you attached in your post above, that the drawing is dated July 21/83 in the main heading, and in smaller print beside it there is a note stating revised 9/23/83, which to me indicates that the drawing you posted, and perhaps the tank size, was revised in September, 1983 for the later 1984 models.
I am reasonably sure that mine is 25 gallons, based on everything I have read, as well as what my fuel gauge shows. I know my engine burns about one litre per hour of operation (ie. I fill with about 20 litres of diesel when my hour meter shows an additional 20 hours of engine operation), and when my gauge was down to about half during a cruise earlier this year I filled with 48 litres of fuel, which converts to about 12.7 US gallons. Although these fuel gauges aren't very reliable, mine has generally shown 3/4 or 1/2 fairly reliably. So in this case by adding 48 litres/12.7 gallons when my gauge showed half full, would seem to indicate that double that capacity would be very close to the 25 US gallons capacity.
I can't see enough of the fuel tank under the floor to determine how it compares to the measurements in your drawing. The two measurements I provided in the post above look similar, but I can't tell if the tank is longer or any other potential differences.
Dave G.
1984 E30+ (SOLD)
I wish I had an original bill of sale ! Definitely not worth removing anything to measure. I have looked through the little info book that was in the boat hoping to find the original order or bill of sale but alas not there. I did however find a typed document for tuning the rig that is different than the one that is posted here on the site for a 30+. The standout difference is that it states the mast should have have 4-5" of aft rake. The doc here on the site says nothing about rake that I recall. Sorry, getting off track but the whole bill of sale thing triggered my old brain into digressing. I guess the only way to know is to run your tank empty and then fill it up. Maybe someone(hopefully) with a 30+(2) has done that already and will chime in.
Yes, the lack of any rake in the original tuning document is puzzling, especially for our fractional rig boats. I have less than 4 to 5 inches, but still find a little bit of weather helm in a strong breeze and no lee helm, so I'm pretty comfortable with my tuning. A rigger once told me that to achieve more mast bend I would have to loosen the lower shroud a bit, but I haven't done that. I might play with that a bit in the spring to see if it makes a difference.
Dave G.
1984 E30+ (SOLD)
There is also instruction on chainplate tie rod adjustment. I am going to try and scan this on my old flatbed scanner and post. Do you know how I get this into the document archives for reference material ?
That would be great, Dave. I don't know how to do that, but if you email Sean, the administrator, he will help you get that done. I think the moderators also know how - - people like Loren, Christian.
Dave G.
1984 E30+ (SOLD)
For your personal review. Docs attached. I'm guessing this was the factory doc from the date shown. This was with the pile of paperwork on the boat when I bought it. The chainplate tie rod adjustment applies to multiple hulls...I will contact Sean to download in library.
  • E30+Tune.pdf
Yeah, Dave, that's very useful rig tuning information, and would be good to have available in the resource section.
Dave G.
1984 E30+ (SOLD)
Brochure I found. The picture page is color but didn't translate and looks bad here. Added Jpg pic..
  • 30+Brochure.pdf
Dave and other E30+ owners,
Following on the posts above about various models of the E30s, I came across the following information in my files. The original E30-I was built from 1966 to 1970 and includes hull #1 to #150. E30-II hulls were built from 1977 to 1979 and include hull #1 to #47. E30+ hulls were built from 1979 starting with hull #501 through to hull #721 in 1987, with none identified after that date.
Dave G.
1984 E30+ (SOLD)
Frank that's great info ! Now we just need to find the last 30+ hull # built with a bridge deck traveler (633,34,35,or 36) and I think we can respectfully assign a "2" (or?) to hulls 637 thru 721. I started a conversation with Seth to see if he could shed some light but never haven't heard from him as of yet.
