Ericson 32' for sale $11,500 Long Island, NY
Kmisch
PRICE REDUCTION: Ericson 32' for sale $9,500 Long Island, NY
Selling a beautiful sailboat.
Boat has just been professionally resprayed -- Deck and topsides -- LOOKS GREAT!!!
New interior varnish, as well.
Cabin sole repainted, too.
New bottom paint (Micron csc)
Barrier coat applied below waterline.
Has Volvo diesel and late model outboard motor (Johnson long shaft), too.
Possible trailer to haul it, available for separate purchase.
Will post more pictures soon.
COMMENTS: The Ericson 32 is a capable easily handled design. She shows well and should be considered to be above average of comparable Vessels.
VESSEL PARTICULARS
BUILDER: Ericson Yachts DESIGNER: Bruce King
YEAR BUILT: 1971 MODEL: E-32
L.O.D.: 31'7" BEAM: 9' 8"
DRAFT: 4' 11" BALLAST: 4,000#
DISPLACEMENT: 8,800# HULL TYPE: Displacement / Fin Keel
HULL MATERIAL: F.R.P. FASTENINGS: Stainless
BULKHEADS: Plywood DECKS: F.R.P./ nonskid
STEM: F.R.P. FLOORS: F.R.P.
COCKPIT: Aft w/ Combings SUPERSTRUCTURE: F.R.P.
COMMENTS: The vessel is of sound construction and of a type consistent with its intended use. She is of a modern design with ample accommodations and quality construction.
ACCOMMODATIONS / INTERIOR
LAYOUT: From Aft, large cockpit, companionway, 1/4 birth to port, Galley to stbd, settee/double w/table to port., settee to stbd. head w/ shower to port, storage to stbd., V-birth cabin fwd. chain storage @ Stem. She is well laid out for Her intended use.
FINISH & TRIM: Mahogany SOLE: F.R.P.
CUSHIONS: Foam and Fabric FURNITURE: Mahogany / Ply
PROPULSION
NUMBER OF ENGINES: 1 TYPE / FUEL: Inboard / Diesel
MANUFACTURER: "Volvo" NO. CYLINDERS: 2
MODEL: MD11c
YEAR INSTALLED: Appears original HOURS: Not reported (recent major service)
EXHAUST: Wet via manifold & approved hose COOLING: Raw water
STARTING: 12V SHUT DOWN: ignition
CONTROLS: (cable) VENTILATION: 12V blower
REVERSE GEAR: "Universal" SHAFT: 1" Stainless
FUEL TANKS: Below Deck, fixed CAPACITY: 22 gal. (rptd)
FUEL LINE: Copper / rubber FILTRATION: Primary / secondary
OIL DISCHARGE PLAQUE: Yes FUEL / OIL CONTAINMENT: Bilge
COMMENTS: Except where noted at the time of inspection no leaks were observed, all systems and Gauges were reported to function properly. Engine beds, shaft, and shaft log appeared to be in good condition. The engine has recently undergone a major service, it runs and appears as new.
UNDERWATER GEAR
THRU HULLS: Bronze VALVES: Bronze ball
STEERING: Direct WHEEL / TILLER: Tiller
ELECTRICAL AND MECHANICAL
D.C.:12V Lead Acid
ENGINE GENERATORS: 12V alternator GENERATOR: N/A
INTERIOR LIGHTING: 12V NAVIGATION LIGHTS: 12V Deck Level
ANCHOR LIGHT: 12V Masthead STEAMING LIGHT: 12V
GALLEY / PLUMBING
SINK: Stainless REFRIGERATION: Ice Box
FRESH WATER SYSTEM: 12V WATER TANKS: Fixed
MATERIAL: alum. CAPACITY: 25 gal. (rptd.)
CAPACITY: 10 gal. (est) BILGE PUMPS:12V / Man.**
COMMENTS: Except where noted at the time of this inspection the Galley was clean and all systems appeared to be operable.
ELECTRONICS AND NAVIGATION
VHF RADIO: "Icom" (not tested) ENTERTAINMENT: "Pioneer" AM FM CD
DECK EQUIPMENT
STANCHIONS / LIFELINES: Stainless
DOCKING CLEATS: Stainless (adequate)
SAILS AND RIGGING
TYPE OF RIG: Masthead sloop MAST MATERIAL: Aluminum
STANDING RIGGING: Stainless TURNBUCKLES: Stainless
TERMINALS: Roller Swage CHAINPLATES: Stainless
RUNNING RIGGING: Dacron BLOCKS: Aluminum / Stainless.
SAIL INVENTORY: Main, 110% Jib, Genoa SAIL CONDITION: Appear good
SAIL HANDLING: "Barlow" 20 STx2, #16
Kmisch
Additional pics...
Kmisch
more pics of interior etc
Kmisch
more pics
more pics of vberth and outside with rails back on
