Ericson 34 Halyard question.
A.Crampton
I have owned my 1989 Ericson 34 for about a year. It only has two halyards rigged - main and jib. There are two other halyard thin 'messenger type' lines in the mast with a small ball on the end of each as they exit the mast. I haven't been up the mast yet to check out the pulleys on the top. Does anybody know if these are a spinnaker and spare jib? If so,what is the process you go thru to rig the new halyards?
Chris Miller
Those halyards can be used for any kind of headsail (jib, spinnaker, or [heaven help us] a blooper)...
whip a messenger loop on the non-shackle end of the halyard and tie the messenger line to it, then pull it through. Make sure to put one back in if you ever remove the halyard.
Chris
