MaineCapeSailor
My E32-3 sold in a week. E38 in good condition in the Northeast wanted
Interesting that the headliner was removed.Have you seen this one yet?
1993 Pacific Seacraft Ericson 380 Sloop for sale - YachtWorld
Find more information and images about the boat and contact the seller or search more boats for sale on YachtWorld.www.yachtworld.com
Smooth painted; no way that PSC would send it out without a headliner. That is indeed odd - must be an interesting back-story. Asking price is oddly low, too.Interesting that the headliner was removed.
I have the batten and panel concept on my Tartan 37 and I like it a whole lot better than dealing with the zippers, rusty staples and the many inaccessible parts of my 32-200 headliner. Tartan and others simply glue some blocks to the underside of the deck and then secure the panels with battens. I have replaced the panels with 1/8" formica sheets from a building supply company.Speaking of a headliner that is a work of art, there's always Martin King's stunning retrofit.
Can you offer some pictures? I'd love to see what you did. And how did you like working with Formica, vs. going with thin wood panels?I have the batten and panel concept on my Tartan 37 and I like it a whole lot better than dealing with the zippers, rusty staples and the many inaccessible parts of my 32-200 headliner. Tartan and others simply glue some blocks to the underside of the deck and then secure the panels with battens. I have replaced the panels with 1/8" formica sheets from a building supply company.
My friend Neil Dutton, who sometimes checks in here, used to work for some of the So Cal. boat builders back in the 70's (Islander, Jensen, and Capital). He happened to mention that at Islander (I believe) they didn't even install their own headliners but brought in an upholsterer and turned them loose on it. Don't know about Ericson or other builders, though.The vinyl headliner looks absolutely daunting for DIYer's with a Sailrite like myself, but for a factory, they probably had a template for each model and could knock them out with ease. Once they were all sewn together, a few somewhat skilled people with pneumatic stable guns could install with great results.
Unfortunately, my Tartan is in Maine under cover and I am in California until May. Happy to take some pictures in the summer. The challenge I see with doing this on the Ericson, is working around the overhead handrails ( a feature I like on the Ericson that is missing on the Tartan). I think there is a way to get around this. Other than that, it seems rather simple to make a pattern as you would for flooring and cut them out. The battens cover a lot of imprecision. You can also have attractive access panels. Seems like Ericson, Islander and others were trying to make the boat look like a car.Can you offer some pictures? I'd love to see what you did. And how did you like working with Formica, vs. going with thin wood panels?
Thanks for this, Ray.Unfortunately, my Tartan is in Maine under cover and I am in California until May. Happy to take some pictures in the summer. The challenge I see with doing this on the Ericson, is working around the overhead handrails ( a feature I like on the Ericson that is missing on the Tartan). I think there is a way to get around this. Other than that, it seems rather simple to make a pattern as you would for flooring and cut them out. The battens cover a lot of imprecision. You can also have attractive access panels. Seems like Ericson, Islander and others were trying to make the boat look like a car.
I should have been more precise. The stuff I used was not actually Formica brand. It is some stuff I got from Home Depot. I am not sure the product I used is still around--I think it was called Wilson Art water proof panels and used in cheap bathroom installations. Was easy to work with with a jig saw. In my case I just used the old panels (which appeared to be plastic coated masonite) for patterns. The battens cover gaps and they are fastened with silicon bronze oval head screws. I learned NOT to put screws in the panels, but rather to suspend the ceiling and use only the battens secure them in place. I would be a complicated job to replace the headliner (because of the overhead hand rails) in my 32-200 and I have no intention of doing so. I think someone from an upholstery background did do the work because who with a boating background would use mild metal staples to secure it?Can you offer some pictures? I'd love to see what you did. And how did you like working with Formica, vs. going with thin wood panels?
I have a couple pieces of that stuff sitting up in the garage. I've been tearing up my cloth headliner to address hardware leaks and plan on installing the bead board when finished.DIY Home Depot plastic bead board...
I have done this several times, around the whole perimeter. Rather tedious work. Acquire a good (preferably pneumatic ) stapler.I can't imagine re- stapling the headliner back into place and someday facing the prospect of having to remove it again.
Yeah, I know people have done this, and it is hard to beat the appearance of Ericson's factory headliner.I have done this several times, around the whole perimeter. Rather tedious work.
