Ericson Table looks teak
EngineerSailing
I've decided this is too big for my boat
But instead of just taking a saw and cutting it down
I wanted to see if anyone needed an Ericson teak table first
I think $150 plus shipping cost would be reasonable
Or pickup I'm in St Petersburg, FL area for now
Has piano hinges and support legs too
Oh my. Is that the very "trick" table that folds up and sort of embraces the mast? (Like the one in the E-33RH in our club.)
EngineerSailing
It
It does attach to the mast
It is thick and heavy
I've never seen a E-33RH
The 33 and 36RH's were designed and started together, so I expect them to be the same
I want to keep the mast bracket to attach a smaller piece of wood for a table
I'm thinking a little bigger than playing a checker board on is right for me
N.A.
E34 / SF Bay
My E34-2 table is missing the half that folds out... does anyone know if this one will fit (they are all similar)?
@EngineerSailing : if you measure the length of the hinged side, I can see if it's the same as that side of my own table.
If this fits / would work, I'm potentially quite interested.
EngineerSailing
Each leaf is 48" x 14"
Both look in very good condition
The center piece is 4" x 48"
Table end Support height 28.5" for table 34.5" overall
I have temporarily (hopefully permanently) removed mine. It takes up an enormous amount of space in the cabin. My wife and I have a slight disagreement about this- she loves the idea of an huge table to play cards etc with friends, whereas I believe even the half table to be too big and prevents easy access to the port settee let alone the entire thing.
I am also agitating for removal of the two wood doors between the v-berth and salon. They limit access to the hanging lockers on each side and don’t close easily. A heavy curtain would be much more convenient.
I don’t expect to prevail on either issue but a guy can dream…
Here is a photo of the leaf, sorry I don’t have one with it open
We love our table with fold-down leaves when in use... kind of makes the cabin seem smaller when not in use... so solid it supports me when thrown against it off shore. "Everything's a compromise" as the saying goes.
As for the teak doors (bi-fold for the forward cabin) and also the aft cabin, we took those off and stored them for the next owner, decades ago. After all, the only "private" place on a small boat is the head, and that door stays on! :)
N.A.
E34 / SF Bay
Now I know what do do with those pesky doors :)
I'll measure my table this weekend and see if it's the right size. Mine looks a bit like the image above, so @EngineerSailing , if yours does not look like that it probably won't work for me. [E.g. you mention 3 pieces, whereas my table, like the image above, only has two: the main table and the fold-down leaf.
I do like having the half-table -- singlehanding I'm not sure when I'd use the full one, but the hinge keeps me noticing its absence.
EngineerSailing
Mine is a little different
For 1 mine has a lip to keep plates and cups from sliding off
Also it is set so both sides leaf down not just 1
EngineerSailing
New price $70 OBO +SHIPPING
if someone could use it is rather it go, because its way to big for me to keep all of it
JSM
I removed the table from our 34-2 when I installed a new cabin sole and never re-installed it for the same reasons. At my wife's urging the v-berth doors are coming off as well.
