No such luck on my little 30+, there are no forward cowl vents. Just the two on the taffrail, one of which is connected to the blower to ventilate the engine compartment. I guess bigger is better for getting cool air into the engine but I wonder where the limiting factor would be- the cowl vent or the blower. I don’t think the taffrail vents do much to cool the boat but may get some circulation going in the engine room. They certainly circulate water in the rainy months.Lot of air comes through those front dorade cowls
I "cleaned" the screens of all my dorade vents with a toothpick and hand vac. The crud buildup from 30-something years was significant - as was the influx of airflow once they were cleaned.If you're not getting much air through these vents, it might be worth removing the teak trim ring and cleaning the screen that's stapled to the top side of it.
Here's what the vents from the dorade look like with the trim ring/screen removed. It's about a 2.5" hole, and it should let quite a bit of air into the cabin and head. My boat is on a bouy, so it's always facing predominantly into the wind. Maybe that helps with the air intake.
FYI, when we get a "bad" spring mosquito season here, they will find a way in..... anywhere.... they can. They are stubborn, numerous, and obnoxious ........What bugs come through a dorade? Maybe the screen is for critters....
I found a couple of dead bees in my screens.What bugs come through a dorade? Maybe the screen is for critters....
