I'm looking for a replacement exhaust elbow, part #170-2834 that I believe was made by Onan, for my 1988 E32-200 with the Universal M25XP engine. See the attached pictures. Any idea on sources for this part?
Also, when I took the system apart I found the water injection port to be nearly 100% clogged. And, alarmingly, there was fresh water with no sign of antifreeze in it that came out of the heat exchanger when I removed those hoses. I winterize the engine by running it with the raw water intake hose inserted into a bucket holding 2 gallons of antifreeze. I also have a bucket under the exhaust so I can inspect the discharge to make sure antifreeze has run completely through the system. The bucket under the exhaust outlet did contain antifreeze but yet there is still clear fresh water in some of the lines and heat exchanger that I had winterized. What gives?? I'm completely baffled by this.
