Fellow Ericson folks, thought I would put out sort of a public service announcement regarding faulty steps. I have an '85 Ericson 28 (new to me in Aug of 2022). We spent about three months doing a light refit, some upgrades and lots of cleaning, etc. Although we looked at those steps and went up and down them probably hundreds of times during the project, I never really thought to look at them closely. Part of the reason was that it still had the original heat shield and sound deadening material glued to the back side of the engine cover.
One day last time out, my darling Pam went down into the cabin and the middle step broke off sending her crashing to the ground. Luckily she was not seriously hurt. But here's the kicker and why I'm putting up this post....... When I went to check it out and figure out the best way of fixing it, I discovered that the step was never installed correctly in the first place and it's a miracle that it hadn't broken long before that (after all it is a 1985 boat). Normally there are a minimum of 3 large screws horizontally securing the step itself, and then 2 screws vertically in each of the the two vertical supports. In this case, only the vertical screws in the supports were ever installed, somebody just missed it and once the heat shield was glued on you'd never notice they were missing. The amount of outward leverage on those lower screws would be huge without the upper ones helping to create more of a "shear" strength to the steps. And it won't be the 35 lb. kid that breaks them and just bounces back up like nothing happened, it will be the 65 yr old 130-225 lb. senior that ends up as the final straw.
I'm confident that this is probably an anomaly, but either way, I can tell you that it would be worth checking all of your steps for how they are secured to avoid what could have been a life changing avoidable accident.
Best to everyone!
Best to everyone!
