Howard Keiper
This is a situation that has developed only recently.
Sea Quest's gas tank is under the cockpit with the filler on the cockpit floor. When I fill the tank, I do it two ways: I had always just poured the gas through a wide mouth funnel...until I noticed the smell. Then I thought maybe the hose from the filler to the tank was deteriorating, though I could never find any sign of gas around either the tank or the hose...or anywhere else near the tank. That's when I started filling by inserting a vinyl hose all the way into the tank, bypassing the normal filler hose alltogether and pouring the gas as before. No luck. The odor is fairly strong, especially when the stbd locker is open.
So, the next thing I did was to make sure the fuel supply shut-off was closed, got down on my hands and knees and 'pressurized' the tank by blowing into the filler hole to see if the vent was open...it was, and my wife got a handful of raw gas to prove it.
There is no leak from or around the carburator that I can detect, nor any sign of gas in the bilge.
Any other ideas??
Howard Keiper
Sea Quest E-35II
Berkeley
Any other ideas??
Howard Keiper
Sea Quest E-35II
Berkeley
