Gooseneck Reef Sheaves--Replace?
I pulled the little reef-line sheaves from the gooseneck. They weren't turning well and no doubt needed replacement. Simple little pulleys--stainless bushing, Delrin sheave.
I couldn't find them at Mcmaster Carr, so then to Rig Rite. Ugh. Then to Goldenstate, who has a good blog intry on Goosenecks parts. ( https://ericsonyachts.org/ie/ubs/boom-rehab.750/ )
Apparently these are nonstandard sheaves. The Rigrite prices are are just preposterous.
7/8" Delrin Sheave - 1/2" wide, 7/16" ID: K-11409: As used on New-style D-Section Gooseneck (reef Sheaves), and in other applications. With rope groove. $22 each
SS Sheave Bushing/Spacer: K-11413:
Stainless Steel Bushing/Spacer is 1/2" OD x 3/8" ID x under 9/16" (.552) long. $29 each.
That stopped my hand from bothering to call Zephyrworks, the sheave shop so often commended here. That's because, on closer consideration, there's really nothing wrong with my reef sheaves that a little care won't fix. They were glommed up with Tef-gel and five years of dust, and I'm pretty sure that when I clean up the gooseneck they'll spin fine again.
At $50 each, they'd better.
I did this on my E32-3 back in 2017 and I remember the hassles well.
I replaced these as well. Yours look pretty beat up which makes sense given all the miles you've put on them. Mine were broken, so I didn't really have an option to cleanup and reuse.
If mine looked like yours, I would still replace them to be proactive. I can't find my invoice, but $50 a piece sounds about right after shipping.
One thing to check is where the bushing seats against the aluminum casting (one of the top two holes in the second pic below). On mine, that area wasn't in great shape and the bushing pressed into the casting enough that when the side plate and bolt were attached, it squeezed the new sheeve instead of the bushing so it didn't spin. I thought about fixing it by putting a washer against the casting to give a clean surface for the bushing to mate against. The issue resolved itself after cleaning up the casting during last year's mast rehab project, no washer needed.
Before:
After:
Let's not forget the gold standard fix that Kranich did:
Today I removed and replaced the small sheaves after careful cleaning. In my case, that was all it took to get them functioning again.
It may be useful to report that although the sheaves were jammed, it was really caused only by Tef-Gel, the very sticky stuff we apply to prevent corrosion between the aluminum of the kenyon gooseneck and the stainless that supports the small sheaves.
The tolerances there are quite small. The ss bushing is very slightly wider than the Delrin body of the sheave, to allow it to turn. Glop of any kind gums up the works.
The small reefing sheaves are critical to smooth function of slab reefing, second only to the big sheaves at boom end.
There is no purchase for reeflines inside the boom, unlike the arrays there for outhaul and topping lift. I think it can be said that if reefing becomes stiff, it's the sheaves. (If it isn't fat line swollen over 20 years, or the 3/8ths originally recommended by Ericson. General agreement now is that 5/16ths is best for our reef lines)
