hard starting?
brassmeister
1989 32-3 with M25XP. It always takes 5-10 pushes of the starter button before the starter engages. When it does engage it starts fine. Is this normal? It's been this way for at least 10 years.
Don’t think so. My M25XP “cold“ starts right away after about 10-15 second glow plug pre-heat. You might at least want to look into this by yourself or a qualified mechanic. Don’t crank the engine too much trying to start it with the seacock open cause that can cause catastrophic damage. Close the seacock and then open it after the engine starts. That short period (like 10 seconds) won’t harm the engine but will prevent damage.
Your start button could be corroded. Your start solenoid could have corroded wiring connections. Both are “easy” to diagnose and fix.
The start button has only two terminals (wire connections). Use a screw driver or other piece of metal to short them together. If the starter is responsive, the button should be replaced.
Checking and replacing the start solenoid is a little more difficult, but doable with an hour’s effort.
There are several relevant threads here, and this is a good one:
I had the starter rebuilt on our prior M25XP at about a thousand hours, and it did wonders for starting quickly. That said, check ALL the wiring connections (pos. and neg.) also.
If you do a Search on 'starter motor' related topics there are others to study over, as well.
Dave G.
1984 E30+ Ludington, MI
Sounds like loose or corroded connection(s). I would check all your connections especially the starter circuit and grounds on the block. Best to disassemble, clean, and re torque them all. I had a similar issue a few years back and that solved it for me.
Dave G.
Bob, I have never heard this and curious what damage would result and what the source is for this ? Hopefully not something that happened to you :)
The pressure of exhaust gases is what pushes the water out of the wet exhaust muffler. Cranking allows raw water to go into the muffler, but without exhaust from combustion, the water can build up to the point of backing up into the engine.
gabriel
Live free or die hard
I don’t have a diesel in my boat but I’ve owned many Mercedes Benz with them, the first place I would look at with that symptom are the glow plugs, glow relay if it’s an IDI diesel.
In extreme cases, if you "overcrank" a marine diesel with a wet exhaust, water can back up into the cylinders causing a “hydro lock” and can possibly crack the block…or so I’ve read. In any case, cranking your diesel engine for long periods usually means that there is an issue that needs to be addressed.
brassmeister
Redid all the starter side connections already with no change. Going to check the starter button as peaman suggested-don't know why I didn't think of that while I was doing the starter side.
I would suggest the wiring is likely the problem. The "trailer hitch" connection for the instrument panel is a bugger and i would recommend replacing it with a regular bus--takes time, but not skills. Also, the main ground for the starter on the 25XP is right below where the heat exchanger and a bunch of plumbing could be dropping leaks and condensation--so I would clean that up with a wire brush. You can check the solenoid as with a screwdriver. I definitely would do the wiring changes and maintenance before starting to replace starters and solenoids.
dandimm
I feel your pain...I have the same, frustrating inconsistent starting issues as you on my 1984 30+. It has a Universal M18 engine. This past weekend it left me stuck for a hour while I had guests on the boat. (panic) I almost had to bear the shame of calling TowBoatUS .
Lot of good info on this thread that I have already tried.
When I push the starter button somethings and I can hear the solenoid click but no start. I push it a second or third time and it starts up. I am still trying to track down the issue. I have replaced the batteries, starter/solenoid, new wire bypassing the trailer connector to the solenoid, new wire to from the starter directly to the key switch, new starter button, did the ammeter mod to remove the orange wire, new fuse holder for the solenoid wire, cleaned all the battery connections and tried to locate all the engine grounds to clean.
I plan to replace the rest of the low amp wires in the trailer harness this fall.
I saw in @Pete the Cat previous post about the starter ground and it got me thinking. Sorry to ask but does anyone here know where the M18 starter grounds at on the engine? I am started to also suspect it is a grounding issue.
Daniel
I suspect this could be a grounding issue, too.
The starter grounds itself to the engine block by virtue of being bolted to it (btw, the same is true for the glow plugs). This begs the question, "how is the engine block grounded to the batteries?" Surprisingly, many Ericson engines are grounded via a (neg) battery cable attached to the exhaust flange. Sounds really dumb to hook a major, high amperage connection to the hottest part of the engine but this is what Ericson often did. The picture below is borrowed from Compass Marine. The black cable on the right-most exhaust flange bolt is the cable that grounds the engine block back to the battery(s).
Ericson used the engine block itself as a "ground bus," which leads to the problem of other multiple, various bolts on the engine being used as ground points. This is a picture of my original engine exhaust manifold, with three of the attachment screws being as ground points.
It's far better to relocate the engine grounding cable to a lower point on the engine and then run a cable to a ground-bus-block on the engine stringer. A separate bus block makes a neat and tidy collection of all ground points that are then connected by a single cable back to the negative battery terminal.
20170506_020746.jpg New ground point.
20170616_231619.jpg Ground bus block.
But the first thing to do is suspect the button itself. They're not very long-lived. Connect the wires, or bridge with a screwdriver, to eliminate this simple possibility. These typical "Mom on" buttons corrode and need periodic replacement.
[Oh, sorry, already said in Post #3]
