Oh my......
There are a ton of issues with Harken Roller furling units that this could be.
The most common wrapped halyards, halyard stuck in the top of the unit. You can also have some binding with the system depending on tension on the backstay or the forestay.
Next the bearings in the bottom are completely incased in salt because it has not been washed in a coons age. I have seen this cause failure in the bottom units bearings quite a few times.
Next is the ubiquitous aluminum on stainless steel bearin system that harken uses. Each of the bearings up the forestay are aluminum and ride on the stainless steel forestay, bad bad bad....
Hardly ever is it the top unit. But if it is, you generally have to replace the whole upper bearing swivel assembly. There are old style and new styles of these, the old ones seem to last longer, but are slightly harder to turn. Send a photo and I can tell which you have. The top swivel bearing assembly is available as a replacemtn unit from Harken. The easiest way is of course to first get it down to deck level or dock level for an inspection.
If you have one of the roll pin models, Harken makes a replacement kit for them. you get new sections, new bearings, and a new feeder, for a really good price. They freely admit that the roll pins in the mark I unit are a bad idea. If you want to purchase an upgrade kit let me know.
Guy
