Ralph Hewitt
San Juan del Sur NicaraguaI'm in Flamingo headed to Quepos tomorrow. I'll be at Pez Vela. Where are you? 1986 38-200
What do they charge for haul-out & splash? Travel lift or crane?? Nightly yard fee?San Juan del Sur Nicaragua
Let me know when you get there...thanksWhat do they charge for haul-out & splash? Travel lift or crane?? Nightly yard fee?
Do they have stands?
Can you do your own work?
Might follow you down if I can rebuild my steerage and get Rudder back on.
Big problems with Keel... leaks!
Will have to motor down.
Not sure of what kind of machine shop you have access to, but "getting the coupler straight" is terrifically important and is generally done by the machine shop (facing on the prop shaft) to make sure. I am not following your stated plan here. I am not sure how you "bring the prop shaft forward" to replace the PSS--my experience is that you have to move it aft, and it makes sense to remove it and the coupling at that point--if you do not have to drop the rudder to do so--while it is out; check the shaft for being true, check the keyways, check it for scoring, and have it faced with a new coupling (only a good machine shop can do this--most boatyards send this work out) that is is absolutely perpendicular to the shaft. My view is that the rear seals on engines and transmissions are generally compromised by poor alignment and shoddy facing of the coupling with the shaft. I realize this is expensive, but cutting corners at this point can create problems down the line. I am probably not understanding your plan.We are hauled right now and replacing cutlass bearing and PSS while we are out. Our engine‘s rear main seal is leaking oil so we have to pull the engine forward and disconnect the shaft to get access to replace it. While it’s forward we are going to pull the prop and bring the shaft forward to replace the PSS. Mechanic told me it can be a bear to get the coupler off and back on straight so better to avoid it since we have access anyway.
It’s expensive. There is a good machine shop next door. Knowledgeable guys. But they don’t have much experience on sailboats. Mostly all large sport fishing boats. You can work on your boat but they charge a fee of $60/ day I believe.What do they charge for haul-out & splash? Travel lift or crane?? Nightly yard fee?
I’m glad you said this. Indeed the PSS shaft seal is shot and I am scrambling to get a replacement.That's a big work list, so get as much help as you can.
The dripless shaft seal would be my priority.
From the looks of those pictures you would have very good access to a conventional, bullet proof stuffing box. Maybe this is a good time to consider ditching the PSS, especially since you are cruising where sourcing parts and finding boatyards can be challenging.I’m glad you said this. Indeed the PSS shaft seal is shot and I am scrambling to get a replacement.
Had a serious issue motoring into very strong current with 30 knots on the nose. Engine was very hot and then the prop shaft coming through the hull at the seal overheated and started smoking then squealing. Had to raise sails and idle immediately and burp the seal. Water was scalding hot. After an hour or so we fired her up and kept monitoring and burping the seal to check temp and cool it and it recovered okay.
Could have been a disaster.
Right again on both accounts! The key was bound into the key way on the coupler. Had to remove it all. Shop is working on releasing it. Doesn’t seem like a new prop shaft is necessary.Also, it is not uncommon to discover the keyway in the shaft coupling ruined after 30-plus years, which will mean a new prop shaft and coupler.
Resist boatyard recommendations to install thru-hull for irrigation of dripless shaft seals, I think for our boats the vent option is adequate.
PSS has good videos:
