You may want to consider a 13ft ships oar or a Venetian Caorlina Stern oar. It can be used as a stern sweep to maintain heading or change course. Used from the Po River in the Veneto to the Salmon River in Idaho it might be what you need for emergencies. If Port Washington can't do it you could, maybe, piggy back on the occasional shipment from Venice to US Gondola companies.Hmmm... I don't know of a closer lift. What I do know is that I personally haaaaaate that narrow channel going into/out of La Conner from the south. It's bordered by rocks on the north side and shoals on the south, it gets crazy choppy in the prevailing westerly, and even more so if the current is running counter... and what I really don't like is that there are no "bail out" options - once you're in that channel you're kinda stuck for the duration. I tend to think of things in terms of "what's my plan if ___ happens?". Every time I go through that channel, I think "what's my plan if my motor decides to quit?".... and I haven't come up with a good answer yet, other than to avoid that route. Maybe that's just me.
If you do go that way, be sure to check tides/currents and wind forecasts to make the trip as easy as possible.
A possibly better alternative is Everett. Yes, about 10 miles further from Oak Harbor, but a much simpler trip, with a destination that has a good boat-yard, good choices of marine services, guest docks, decent restaurants and even hotels if needed. Oh, and two decent marine hardware stores (well, one good one, plus a West Marine).
$.02
Bruce
It's not about propulsion. It's about maintaining control of the vessel when the engine dies, there is no wind, and there is a strong current running. An oar would be a specialized tool for this location that allows you to steer the boat when your rudder won't. The oar blade has more surface area than a propeller and will shift the vessel any direction you want. Anywho...just don't want you aground.Thx.
I know how to make my boat go without an engine. It's, like, practically a sailboat.
My point was that I like having options, and I don't like putting the boat in places where "if just one thing goes wrong" things can go really wrong.
That channel headed south out of LaConner is one of those places, for me...
B
I suppose you could build a "yuloh" but you'd have to find a place to store it on board the rest of the time.It's not abut propulsion after the engine dies? I thought you were kidding about sculling a 32-foot sailboat with a stern sweep in an emergency.....
