Last week's heavy rains in the Annapolis area resulted in a significant leak running down the mast inside the cabin and also a steady string of water from the interior teak trim around the mast. I checked the newly installed mast boot and don't believe that the water is getting in between it and the mast. Most likely path appears to be under the mast collar or around the bolts holding the collar to the deck. Does anyone have experience removing the collar from a late model E-380? PSC couldn't tell me who made these collars for the PSC E-380. LeFiell did not supply them with the mast.
Vince Benn
"Wild Blue"
E-380, Hull #22
Vince Benn
"Wild Blue"
E-380, Hull #22
