Gmilburn
Hi all,
This weekend I sent my son to the marina to get a couple gallons of gas to top off my E-29 (Atomic 4) gas tank while gas was cheap. He grabbed a 2 gallon plastic gas container that he thought had a couple of inches of gas already in it, filled it up and we funneled it into the tank. After motoring out of the marina, the engine abruptly stopped and refused to restart. By now I suspected bad gas or water in the gas can. Indeed my son now remembers using the can for some other purposes (ie water transport). Sooooo after sailing back into the dock (I was shooting for the slip--but just sailing in there (rather than motoring) was scary enough, that I consider "close to dock" a victory), I drained a few gallons of bad gas out of the tank, at the turn off valve behind the A-4. I know that I now need to 1) finish emptying the tank, 2) empty the sediment bowl and 3) drain the carburator. But what is the next step?
Do I flush the gas tank with a gallon or two of "good gas"? How do I dispose of "rinse gas". Should I use "HEET" or IsoHEET to remove any remaining moisture? (IsoHEET claims to absorb 5X more water than HEET). Any advise would be appreciated.
Additionally, I just read in the current issue of "Practical Sailor" about the concerns and fears of ethanol laced gasoline, particularly about phase separation and marine applications. Is this a real problem--or has this article "over-thought" the problem. I'm concerned that most automobile gas pumps now claim that their fuel may contain "up to 10% ethanol"--but asking the attendent gets you nowhere as to whether it really does or does not. I just hate to pay $4 gallon gas at the marina, when it is $2 at the pump.
Again, any advice would be appreciated.
Gary
Hydrophilic 1977 E-29 Hull 515
Gary
