RON CARTER
since we purchased AZGARD last april we were driven crazy by this sound at 1400-1900 rp and have learned that two p.o. had same problem. Sept this year we replaced original M-25 universal diesel with a NEW universal XPB 25 and much to our horror we have the very same noise at 1400-2000 rpm. The only parts we did not replace were shaft and prop, 16 inch x 10 pitch r.h. fixed 3 blade.......... Can this hum /whine noise somehow result from prop turbulence between prop and hull ??? Local dock experts suggest changing pitch very slightly may help which I can do as we only attain 3000 rpm peak against 3200.
Has anyone had similair noise on ERICSON 35-3 AND HOW DID YOU CURE???
