stgermain45
Yesterday when taking our 1987 E28 out, the engine would not rise above 2200 RPM. She is normally capable of well over 3000 RPM with the manual quoting 3600, though I'll never test it. I typically don't ever force her above 2600 RPM, which is at the low end of the manual's cruising recommendations. It is a Universal M12 10HP diesel engine with about 225 hours on it. As an experiment, I forced the arm to full throttle, but there was no increase above 2200 RPM (not just a meter rating - no power increase while giving more throttle). Also, a slight backing off of the throttle produced a rapid drop in RPM and considerable loss in power. I can't speak yet as to whether these symptoms occurred in neutral as well, but will check when I'm down at the boat next.
I found this related thread and plan to look into some of the advice offered:
http://www.ericsonyachts.org/infoexchange/showthread.php?t=2523
Can anyone think of other possible things to look into? The diver was at the boat just a few days ago, so I'm doubtful about debris on the prop, but haven't yet stuck my head underwater.
I changed the fuel filters recently but have taken the boat out under power since then without any issues. Other than pulling the dipstick to check oil, I haven't touched the engine since successfully motoring about a week and a half ago. One additional thing I noticed was that the throttle is also pretty tough to throttle up/down and requires considerably more arm strength than would normally be comfortable - it seems to have progressively gotten worse since purchasing the boat in August.
I should probably also note that we redid the entire wet exhaust system due to a cracked riser several months back and with all new hoses (including coolant hoses and a brand new hot water heater, given the opportunity of access). However, we've motored without any problems probably 20 times since. And there was nothing unusual about the amount of water out of the transom thru hull yesterday.
Air filter has been recently replaced a few months back as well.
Any ideas?
Chris
Any ideas?
Chris
