I think Christian is right, try to gently tighten to see if it has a effect. That assembly is there for a reason, likely hiding a cone nut or cam. Maybe an off the shelf shim or washer will compensate for wear, perhaps it is the table post that is deformed. My post is deformed, as well as the base and top clamps, so it wiggles a little(my model is like Christian's 381 beige one) . If you can't get factory support from Zwaardvis, or other source, take pictures as you disassemble it, so you don't have to guess multiple times how it goes back together, a lesson I often relearn from time to time.
