I like the True North heater because it cannot tip over, regardless of how much the boat is knocked around in a gale. I also keep all countertops and seat cushions cleared of items that might fall, so nothing is going to fall on top of the heater. Plus the electrical panel circuit will trip and the dock shore power circuit breaker will trip if there is too much current draw on the AC circuit. That seems safe enough for me.
I didn't mention this earlier, but I also keep all access doors to the thru hulls open, so all these spaces should be kept above freezing by the heater.
Attached is the description from the manual for setting the heater to "Antifreeze mode". It describes the setting better than I can. I set the fan speed to 3 or 4. The heater does not run continuously. It might turn on briefly every five minutes or so when the thermostat is set to antifreeze mode and the boat is cold enough. To test the heater, you can turn the thermostat dial all the way up to the "+" setting and then the heater will start and stay on.
Yes, the Stop-Dry dehumidifier isn't a dehumidifier. I had a real dehumidifier previously, but had the same problem as
@bsangs. It would freeze up in the winter, so it was pretty useless.
Once the weather warms up, the True North heater stops running. I also have the Stor-Dry because my understanding is that circulating the air in the boat cabin is an effective way to prevent mold and mildew. I will say that I am fanatical about chasing and fixing leaks. And, the bilge stays dry all winter long. Yes, I'm
that guy. The combination of low humidity (no bilge water) and gently circulating air have kept our Ericson mold and mildew free every winter. We've had other leaky boats that required serious cleaning in the spring, so we are motivated to prevent this on the Ericson.
