I had a small leak which I believed was coming from where the mast electricals pass through the deck. I decided to address the problem. Since I would need to unstep, I thought I might as well replace all the standing rigging. Since I was replacing the standing rigging, I thought I might as well replace all the running rigging. Since I was replacing the running rigging, I thought I might as well get new lifelines and pelican hooks.
You get the picture.
Anyway, the leak was at the base of the mast. It also appeared that the aluminum mast step was corroded - so I had a new one ordered and installed.
Since the rigs has been put back up, I had a weird feeling that the spreaders were not perfectly aligned. I chalked that up to an optical illusion as it's hard to tell what's straight and what isn't from just walking around the boat. Recently, I decided to investiagte more carefully. Looking up at the spar from the small hatch just aft of the mast did indeed confirm that the spreaders were a little out of alignment (maybe 5 to 7 degrees?). I applied a liitle fore and aft pressure to the shrouds, which seemed to help a little.
Anyway, I've raised the issue with the folks who did the work, and it is my best guess that the new mast step wasn't milled exactly like the old mast step - accounting for the misalignment.
Is this a major problem? Should I be thinking about unsteping and re-doing the mast step (perhaps by re-milling the bolt holes)? On the other hand, would the learned folks on this board consider this to be a non-issue? Is some small amount of less-than-perfect alignment common?
All comments welcome!
