Mast rake
I would agree a small amount of rake is a good thing for the 35-2-between 1.5-2.5" is where I would start, but I have sailed on a number of them with 6" or more.....it depends on how much breeze you normally sail in, and how much you want to favor upwind ability vs. reaching and running performance.. A good way to tell if the boat is well balanced is to go sailing, using the right sized headsail for the conditions, but stay betwen about 7-15 knots TWS (doing this test in over about 15 knots TWS adds too many variables). This means a 150%(ish) sized headsail if under about 10, and a 130 (ish) if comfortably above 10. If you only have a 130% genoa, do this test in at least 10 knots of TWS...
Sail upwind-making sure you have the genoa trimmed correctly with the leads in the right spot, and the mainsail correctly trimmed-nothing more than a small bubble (if any) in the luff, and all leech telltales streaming (top one can be stalled about 50% of the time). Assuming you do not have unusual amounts of weight in either end of the boat, from a solid close hauled course (and with the boat up to speed), let go of the wheel/tiller (if a wheel be sure the brake is off)...The boat should slowly head up into the breeze. If it goes dead straight, or bears away from the wind, you should add a little more aft rake. If it snaps up suddenly into the wind, you may have too much aft rake (but first double check your main was not overtrimmed!).
Michael-FWIW-your backstay adjuster is not intended to increase mast rake-it is intended to do 2 things: induce (or reduce) mast BEND to optimize mainsail depth, and reduce (or increase) headstay sag. Mast Rake, unlike bend, does not impact sail shape (okay, it can affect genoa clew height), it changes the balance of the sailplan vs. CG of the boat.
What you are seeing when you apply backstay seems similar to rake because the 35-2 mast is so stiff and does not bend much, and you are seeing the top of the rig move aft.. but the best way to do this with the 35-2 rig (if equipped with an adjuster) is to measure the rake with a SLIGHT amount of backstay tension-whatever you would leave on while at the dock. If you want more rake- EASE the HEADSTAY off in 1/2" increments, and measure with the bob. If you do not see any movement, then take up the exact same amount on the backstay, and re-measure.. When you arrive at the desired rake for your next test sail, pin the headstay. Now, when you are under sail you will have the desired rake, and you can use the backstay adjuster to fine tune the headstay sag, and flatten the mainsail with bend-as needed. You will find the mast bends much better with the aft lowers quite loose-as they normally should be..
The rule of thumb is to use headstay length as the determinant for rake. If you do not have a BS adjuster, then when you are adjusting rake with the headstay, be sure you ease or take up on the backstay the same amount when you are done (if you eased the headstay an inch, take up on the BS an inch, etc.). This way the relative rig tune should not change with the change in rake...
Enjoy!
S:nerd:
