tremellose
Hi,
I started a post about a month ago regarding repairing/replacing a broken spreader bracket - here is the link http://www.ericsonyachts.org/infoexchange/showthread.php?t=7781
Well, my dad and I took the mast down yesterday without any real trouble; The only thing was that the VHF radio cable was run right from the top of the mast through to the radio - I was expecting there to be a coupling of some sort that I would just undo once we picked the mast up; so given that the mast was hanging there I cut the cable.
I've attached photos of the broken spreader bracket and mast collar.
I ordered new brackets and spreaders from Dwyer Mast as was suggested from a fellow poster and they arrived today. As the brackets are not shaped to form to my teardrop shaped mast I'm not sure how to go about attaching them - any suggestions here would be wonderful; also, as you might be able to see in the pictures, the mast is dented where the old spreader brackets were - another poster on my last thread suggested a sleave to go around the mast - any other comments on this idea?
The last thing is that one of my goals in unstepping the mast is to secure the VHF cable from slapping inside; I've had some suggestions and read some posts which included running pvc pipe to drilling holes and securing the lines with wire and pop rivets to foam - the owner of the boat I'm tied up against at the dock suggested something like a styrofoam pipe insulator with a split - that I could just wrap around the cable and feed it up the mast - what do you think?
