EGregerson
Hi; Anyone with experience in installing mast steps on a kenyon mast for a keel stepped E-34? Opting to climb rather than swing (at 6'5" 240, swinging presents certain problems), i've picked up a box of WM steps. The mast has a seam running down the middle of each side. I expect it to be thicker there. How thick is not known. It appears I could drill 2 holes on either side of the seam (2 up and 2 down) then hope for the best on the center bolts. The 2nd problem is the media to separate the ss bolts from the aluminum mast material; I've heard locktite will protect the mast; does anyone know of a better (purpose built) coating for the threads?
