seabreeone
My Ericson 35-2 . Both my main and jib sheaves are frozen solid making it almost impossible to raise the main. Jib is on roller furling when I took jib sail down to clean it. It also was very hard to raise. I had one guy go up the mast and he sprayed pb blaster on sheaves and could brake them loose. He claims the way masthead is set up he can not pop out the pins and replace the sheaves like you can on a Catalina? He said I will have to take down mast to replace or free up sheaves? Got a quote from shipyard to pull mast $1900 to $3000.00 With mast lay days. Outrages to free up or replace 4 sheaves.
I was thinking maybe go up with a heat gun or small torch heat them up and try to free them. I don't know. Has anybody had this type of issue? How did you free them up? Thanks..
