Time sure flies! It was 2001 when I started a thread on the reformatting of our drinking water system. All has been well. Then, a couple o' days ago the pump quit moving water. Motor turns and made appropriate sounds, but no water came out of the taps...
Pump is the new ShurFlo 2088-423-344 installed when I did the system upgrade in '01. It still looks like new. Since we had planned to go out for the night this current weekend (and we did!) I swapped back in the old grotty-looking ShurFlo pump probably installed when the boat was new in '88.
It works but the check valve is not operating. This got us through a nice night on the river and is still pumping water fine. (Without a check valve the accumulator is without purpose, though.)
I note that I can source another same-model pump new for prices ranging from 80.-ish to well over $100. Rebuild kits for the pump/switch part of it appear to be available, also.
A look at the web site for West and some other major outlets shows a replacement model for this pump at about $115. @ West, the Aqua King 3.0 GPM. Mine is rated 2.8 GPM.
Anyone here rebuilt one? Have experiences to share? I ask because I suspect that Ericson put these on a bunch of different boat models in the 80's.
http://www.shurflo.com/pdf/marine/ProductDataSheets/pds-2088-723-244.pdf This is a link to the parts diagram PDF for this pump, FWIW.
Thanks for your help, as always.
Loren in PDX
1988 (Ericson) Olson 34
Loren in PDX
