greg harris
had new beta marine 25 engine installed on my 1988 Ericson 35-III by a yard in New Jersey. The engine comes with a flexible coupling to fit the prop shaft to the engine and Beta says to use it. the quite experienced owner of the yard claims flexible couplings are for people who cant properly line up the engine to the prop shaft. So he left it off. Beta literature say to use it to reduce torsion vibrations and some literature says you should always use a flexible coupling when you have flexible engine mounts. Traveled 5 days under power and what a nice engine and vibration is very minimal.
but figure i should put the flexible coupling in as it is recommended by the manufacturer. The easiest way to do this is leave the engine mounted where it is and just let the prop shaft extend aft the extra width of the coupler which is maybe an inch. Any thoughts from anyone qualified to address this. i would have to relocate the line cutter on the shaft but that's no big deal.
any thoughts.??
thanks
greg harris
any thoughts.??
thanks
greg harris
