Here's the progress on the new cockpit floor. After removal of a peat-bog like substance - 30 year old MUD! A large hole in the inner skin was revealed. I Taped a peice of foamcore (real estate sign) to the underside and started with a 3 of layers of cloth - then added 1/2 inch balsa (wetted out) and installed 3 more layers of 10oz cloth. I didn't bother with the old skin but in hindsight it may have made for a neater job. Now for the fairing - but I'm not fussy - I'm going to build a cedar grate for the bottom so as not to waste too much time fussing about level.
I drilled for and installed new scupper drains. (modified PVC plumbing fittings) and crossed them to the thru-hulls (new hoses too). I chose to glass over the port side drain in the aft "helm Pit"> I figure one drain is enough in that small space and its an extra 6-7ft of hose and another "t" that doesn't need to clutter up the space below.
Now to move the fuel fill outboard on the starboard side between the winches and run to the new tank. (more on that later)
Here are the initial snaps. More later.
Fair winds
jt
Fair winds
jt
