Well, I'm happy to say I've closed the deal on the E26 that I've been asking questions about re: cockpit led reefing. I worked on the boat over the weekend and with the help of the previous owner measured for new sails. Today, I met with the sailmaker and those are underway.
Attached are a couple pictures of the boat. It needs just a little work - cleaning, new blower, and a holding tank installed. Two questions for you folks:
* Has anyone found the tiller steering on the E26 to be somewhat stiff? I thought I was *patiently* working the rusted grease fitting to replace it, but I snapped it off. Neverthless, I was able to put a fair amount of grease into the hole after I drilled it out - it seemed to improve things a bit. The tiller isn't so stiff as to be unusable - it's as if I had a brake turned on it. I don't see any sort of brake - the PO says it's probably just a matter of sitting and that it should ease up a bit once it is in the water.
What is the typical feel of these boats?
* The interior cushions are in decent shape, but dusty and smell a bit of diesel fuel. I cleaned out the bilges carefully and the boat smells quite nice right now. The PO says the fuel smell is primarily from him spilling oil when he last winterized boat (it has sat for two years). That seems likely. But any case....since I'm finding the zippers to the cushions frozen, has anyone... A)found a great way to unztick frozen zippers so I can dryclean the cushions B) found a good way to clean upholstery with a steamer, or some spray treatment? Right now, I have cushions on back deck, taking in sunlight and fresh air for the next few days....
Bill
Bill
