JamesBlakeJones
Listmates, I have a 1989 Olson 34 with a Universal M25XP 23 h.p. diesel engine. It has been quite reliable. For better or worse, the only service I've done is changing the oil twice a year, changing the zinc in the ?heat exchanger, and changing the fuel filter. Now, the engine puts out black exhaust water at times, particularly when revved up, under load. Sometimes it streams black liquid right after you throttle down. A couple of years ago, I put on a Max Prop propeller. They set the pitch to match the Gori that was on there before. Is this black liquid from the exhaust a serious symptom? Do I need to change the prop pitch? Could it be a dirty air filter? (The wire mesh interior air filter is coated in oil and needs to be cleaned). Are there other possibilities? How do you get the prop pitch correct? My tachometer is erratic and I don't trust it, so I'm not sure at what rpm the symptoms are occuring.
Thanks in advance,
James Jones
Olson 34 "Sunwood"
Seattle
Thanks in advance,
James Jones
Olson 34 "Sunwood"
Seattle
