Hi All,
trying to decide which way to go with my outhaul. It is a direct 1:1 setup right now, which means if the sail is up, it's pretty useless, and even heading up it still requires a ridiculous amount of effort for a nice tight foot.
I have seen small winches mounted on booms before. This was my first thought. my second thought would be to try to rig up a 6:1 setup internal to the boom. The issues here are fitting it all in the boom - think would be limited to triple 30mm blocks, maybe a pair of triple 40's, but probably 30's, and modifying to boom to attach one end of the 6:1 internally, which I could probably do pretty easily with a through-bolt.
So, any thoughts on this? The winch strikes me as the easiest way, but perhaps I should try to make it internal.
Thanks in advance.
Thanks in advance.
