For small boats I have never understood the allure of fuel polishing, which a diesel does automatically by running the fuel through the filters.
Yes, my engine does have that and to be honest I’ve never had an issue with “buggy” fuel. I think the creator of the video was trying to solve a problem with “buggy“ fuel he’s purchased from questionable sources. Although the portable idea is a cleaver one I think he’s “over solved” the problem. I would think a better solution would be to have TWO primary filters off the fuel tank that could be selected with a valve. If the engine begins to act up and you think it could be a clogged filter problem then you just switch over to the other primary. A better solution I think to a situation where loss of the engine is critical.If your engine has a bleed knob on the injector pump, you can open the knob fully, turn on the lift pump, and cycle quite a bit of fuel through the system and the filters without even running the engine. I always do this for 10 minutes or so before starting if the engine has been sitting for a long time without a run. Then I know there is freshly filtered fuel in the lines before starting.
Shouldn't the Racor 500 filter trap the goo before it enters the fuel line or you found goo upstream of the Racor?Then I had a particularly bouncy trip to Nova Scotia and got goo in my fuel lines that was like those fake night crawlers fishermen use--the things were so elastic and adhesive you could barely remove them. Somehow the inside of my tank had become suddenly so infused with filth, I ended up having to manually pump my fouled tank and discard 30+ gallons of severely polluted fuel. I conjecture that this stuff somehow grew in my tank and was able to survive the Biobor and perhaps clinged to the top and suddenly let loose in the seaway.
Nope. The goo was in the line from the tank to the Racor. Years before I had had a problem with the screen on the pickup tube, but I took that off. I had several pieces of goo about 6" long in the fuel line from the tank. Eventually the crud blocked the check valve fitting in the Racor 500--which was devilishly hard to diagnose. I note that lots of folks think this is a great filter. I realize the elements are cheaper, but I really do not agree that it is worth replumbing your system to put one in--my experience with the check valve told me there was an additional potential failure point in this setup. I sold mine and put a disposable cannister type in--Yanmar puts this in every new engine they sell--perhaps because their engines are self priming and do not need any kind of valve to hold the fuel in the line to the filter while you change it--though I have a manual valve.. My goal is to eliminate potential failures and simplify. In my cruising years, I met a lot of folks trying to fix sophisticated stuff in exotic places and not doing much sailing or exploring. Others will have other opinions.Shouldn't the Racor 500 filter trap the goo before it enters the fuel line or you found goo upstream of the Racor?
Yeah, I've had that thought too. I still have the original frame-mounted Fram in-line filter and a spin-on canister filter.I note that lots of folks think this is a great filter. I realize the elements are cheaper, but I really do not agree that it is worth replumbing your system to put one in...
I'd read about that, the physics made sense, and I thought it pretty cool. Now that you mention it, there'd need to be quite a flow to create the toilet bowl effect. Though, perhaps I misunderstand the operation of the 'turbo'.. . .
I got a kick out of Racor's marketing hype, in the video above, regarding the "turbo" effect (or whatever they called it) of spinning water out of the fuel. In reality, it's gravity that separates the two, but you can't charge customers extra for gravity.
A note about fuel tank mounting.
We do NOT recommend your using our deck plates for access directly into a fuel tank.
Through the deck above the tank? OK. But into the tank itself? No.
The diesel fuel would "eat up" the molded o-ring over time and would allow fuel to leak - a totally unacceptable situation. You are better off using an aluminum or stainless steel plate and a diesel-compatible gasket material, attaching this plate onto the tank with through-bolt fasteners.
I like the idea of being able to inspect the tank without having to remove a ton of bolts. My only concern would be using a plastic inspection port on a diesel tank. Do you know if it's designed to be used in that way (No judgement here, I have a wood inspection plate and I'm pretty sure that's not exactly ABYC approved)
I could barely change the canister type filter at the dock without slopping around fuel. I can't imagine changing one of those things in a seaway.Nope. The goo was in the line from the tank to the Racor. Years before I had had a problem with the screen on the pickup tube, but I took that off. I had several pieces of goo about 6" long in the fuel line from the tank. Eventually the crud blocked the check valve fitting in the Racor 500--which was devilishly hard to diagnose. I note that lots of folks think this is a great filter. I realize the elements are cheaper, but I really do not agree that it is worth replumbing your system to put one in--my experience with the check valve told me there was an additional potential failure point in this setup. I sold mine and put a disposable cannister type in--Yanmar puts this in every new engine they sell--perhaps because their engines are self priming and do not need any kind of valve to hold the fuel in the line to the filter while you change it--though I have a manual valve.. My goal is to eliminate potential failures and simplify. In my cruising years, I met a lot of folks trying to fix sophisticated stuff in exotic places and not doing much sailing or exploring. Others will have other opinions.
