Magma on a Trailerable
Kim & other BBQ grill worshippers,
One of our boats came with an older Magma and when we looked to purchase replacement parts that we needed, the cost was 70% of the price for a new one! We purchased a new one and salvaged more use with the older one for beach BBQ's with charcoal briquettes and we also take in it the airplane with us. The mfg's want to have you purchase new ones, not restore the older ones - at least this is the impression I have with Magma.
We have the new 14.5" Magma on "Seahorse" and I built the stern mount for it with some solid stainless bar, a couple of dinghy pintles from WM, and a block of teak. I positioned it on the transom where I can swing it out over the water for cooking or inboard onto the split backstay and hold it there with a bungee. It remains outboard of the stern, completely out of the way of the entire cockpit and all sailing operations. We are usually on fresh water and the grill seems to weather there just fine under its blue cover. We haven't noticed the wind blowing out the flames yet. We remove it when trailering and store it indoors when the boat is sitting at the house. I did replace the virtually useless, under-engineered "string" holding the top to the base with a swaged piece of SS rigging wire to prevent losing it overboard.
I also installed a quick disconnect fitting and set up the correct pressure coming from the refillable propane tank located in the cockpit to the grill. I have tee fitting that sends another propane line down below to the propane galley stove, also with a quick disconnect, but naturally, I had to deal with a different gas pressure. I have now spent something north of $170 for a dual purpose gas hose with different regulators to eliminate $2.00 bottles of propane. I am self-smarted, but it actually works really well.
I can post pictures if anyone is interested in seeing my complete setup.
Steve Swann
E25 c/b
