Adding a tach.
Mike, Fitting a tach is all well and good but bear in mind that if the manual or the factory rep technical person can't give you the maximum and sustained cruising RPM's (two different numbers), having a tach won't help in determining the correct prop pitch for your boat. To clarify, the two different RPM's, given my engine as an example, are that mine should be able to reach 3,600 RPM maximum but can only be run at that speed for one hour before overheating the engine whereas the sustained cruising RPM is 3,400 RPM. Now that's my engine, a totally different design from yours so please don't infer from the above numbers that your numbers will be the same. I was merely clarifying the reason for two different RPM's stated for my 3GMF. So I guess if it were me, I'd want to see if those numbers can be gotten before going to the expense of buying and fitting a tach. Come to think of it, my tach gets pulsed information from a wire attached to a magnet in the bell housing that responds to another magnet whirling around on the edge of the flywheel. You might be taking on waaay more than you want to by adding a tach unless you can see evidence of a magnet or dummy plug in the bell housing that would suggest a tach for your engine as an option. But then what do I know? It could be that fitting a tach to your engine is a totally different set up. Check with that rep for an answer to that one. Without blaming him for any inaccuracies, I fell it necessary to invoke Loren's 2 cents worth of value to all the above that I've written. But I think you get the flavor of what all I'm trying to share with you. Good luck, Glyn Judson, E31 hull #55, Marina del Rey, CA
