Hi All,
First time poster here.
I'm interested in a 1982 Ericson 33, though she needs a bit of work. One issue of note is some grounding damage to keel on the bottom and trailing edge. Looking at the hull-to-keel joint as well the forward edge and aft edge where the keel stub meets the hull does not show any signs of cracking/compression damage or separation. The interior grid in the bilge area doesn't show any signs of cracking either.
My question: is the grounding damage in the attached picture bad? My initial thoughts, along with the facts mentioned above, that it is fairly minor and can be faired back into shape. Epoxy barrier layer with thickened epoxy to fill seemed like a good method of attack.
Thanks in advance!
-Ben
P.S. Full disclosure, this is cross-posted on another forum. It was mentioned that I may receive more pertinent information on this site.
Thanks in advance!
-Ben
