I have owned my 1989 E35-III for a 3 years now and am thoroughly enjoying the boat.
Recently the Autohelm 6000 died.
I found a new Raymarine S2G with warranty on the internet at a great price point and installed it along with a ST6002 plus.
After finishing the install and doing the required calibrations a couple of issues remained. Whenever I push the auto button, I get a Rudder Reference error for about 5 secs and then the autopilot engages and seems to work just fine.
Also doing autolearn when I push auto as the last step before the autolearn process actually starts I get a "calibrate" message. The boat makes some turns back and forth and then goes into a hard right hand turn. So much for autolearn.
I decided to call the Raymarine Tech support and to my surprise was told I needed to install the rudder reference sensor even though previous models didn't require one..... The tech assured me the two problems would go away.
Has anyone had this experience and ened up installing the rudder reference sensor? If so where did you find room to install the sensor?
By the way, I still have the original Yacht Speciaties wheel steering, rudder quadrant, etc..
