wolly bugger
I'm in the process of re-beading some deck hardware. Some screw hole had soft wet wet wood which I was able to remove with an allen wrench. I'm just about done with some re-core at the anchor locker, so I was please to find that it haven't spread yet and pouring a plug should do the trick. My liner inside the cabin is fiberglass so it cannot be easily remove. So now, how do I keep the epoxy from running down between the liner and the cabin deck? If its thick enough to keep it from running will it be hard to make sure I don't leave any void at the core level?
any help will be appreciated.
