Luffin it
I need some pointers on removing my motor. I purchased the O/H manual from Don Moyer, which is really worth having, but I did not see anything about removing the motor from the boat. I was going to re do my valves, which I had the two exhaust ones sticking. After removing the head, manifold, carburetor, fuel pump, alternator, starter and the wiring I have decided to pull the engine to clean it and paint it this winter. I will then do an inspection on the lower end and replace what is needed. Since Luffin It as been in Salt Water since new (1979) and the brackets for the transmission cable and throttle cable are rusted be on belief, I will be fabricating new brackets and cleaning the engine compartment. My plan is to machine some stainless ones so I will not be dealing with this again. Getting back to the removal, I was going to us a come along with a rolling trolley off the boom. The trolley will ride on the groove giving me movement fore and aft. Do I remove the bolts holding the motor mounts or would I remove the nuts holding the engine down to the motor mounts, my problem there is raising the motor verticality to clear the studs since I do not have a vertical pull at that point. I could build something if I had too. I am adding freshwater cooling and the oil filter system, which Tom Stevens sells (Indigo Electronics). I added his three bladed prop last year and it is the best investment so far. The boat now backs up with total control and cruises at 6.5 knots with ease. Any info from someone who has done this could help. Thanks so much.
Tom Miskell
Ericson 27 Hull #1287
Luffin It
Tom Miskell
Luffin It
