Following winter out of the water, the only thing that doesn't seem to work is the bow running light. I believe I've traced the problem to bad wiring somewhere between the panel and the light itself. This upcoming weekend, I plan to run temporary wiring externally to determine which wire is bad.
If and when I need to replace a wire to the running light, is there a tried and true method of doing this? The routing seems onerous at best!
Greg
E-28
Hull #673
Greg
E-28
Hull #673
