standardhuman
Hello all,
I'm in the midst of replacing the sole on my '81 E28+. I had a few soft spots that weren't getting any harder, plus some water seepage from an unknown source appearing at the bast of the galley, so here we go:
The floor came up in strips, chips, and fibers, much as has been reported on other project threads.
<table style="width:auto;"><tr><td><a href="http://picasaweb.google.com/lh/photo/WbBjFOQ5ySt0O4Zp2VpMtFJr6DfRErIBmZXm78cdltk?feat=embedwebsite"><img src="http://lh3.ggpht.com/_d-5ZEBxjDiw/TLibmGpyEhI/AAAAAAAAR_0/Wumtew7BOOI/s400/IMG_20101009_150613.jpg" height="300" width="400" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="http://picasaweb.google.com/standardhuman/SoleProvider?authkey=Gv1sRgCKeI3Z6gwK_zfw&feat=embedwebsite">Sole Provider</a></td></tr></table>
Thin teak and holly veneer over plywood. Using a chisel and mallet, it all came along pretty well. The biggest slowdowns came along the edges where the plywood was under this fiberglass overhang by a few inches on the port and stbd edges. The t&h only meets the edge of this ledge whereas the ply extends under it until it meets the hull. Because this fiberglass appears too have been laid after the floor was installed and because the ply was often in poor condition in these areas, the ply usually broke off under the ledge, leaving me to chisel, pry, and pull it out in chunks with pliers.
<table style="width:auto;"><tr><td><a href="http://picasaweb.google.com/standardhuman/SoleProvider?authkey=Gv1sRgCKeI3Z6gwK_zfw&feat=embedwebsite#5528342207949206482"><img src="http://lh3.ggpht.com/_d-5ZEBxjDiw/TLid8p2cc9I/AAAAAAAASB0/uzbBOG5bLE8/s400/IMG_20101012_234032.jpg" height="300" width="400" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="http://picasaweb.google.com/standardhuman/SoleProvider?authkey=Gv1sRgCKeI3Z6gwK_zfw&feat=embedwebsite">Sole Provider</a></td></tr></table>
<em>Here is a section of plywood in very good shape. Note where it meets and goes under the fiberglass ledge</em>
The floor was supported at the by 6 V shaped wood blocks wedged into the bilge on the center line. These blocks were vertically supported by some hand laid thin fiberglass walls for each block and on each side of the bilge. The blocks were able to be lifted straight up and out of these tabs, leaving this thin, sharp-edged, blades sticking up all down the bilge.
<table style="width:auto;"><tr><td><a href="http://picasaweb.google.com/standardhuman/SoleProvider?authkey=Gv1sRgCKeI3Z6gwK_zfw&feat=embedwebsite#5529557291988365474"><img src="http://lh3.ggpht.com/_d-5ZEBxjDiw/TLzvD2ojMKI/AAAAAAAASHA/hRwfUTaBip0/s400/IMG_20101018_175743.jpg" height="400" width="298" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="http://picasaweb.google.com/standardhuman/SoleProvider?authkey=Gv1sRgCKeI3Z6gwK_zfw&feat=embedwebsite">Sole Provider</a></td></tr></table>
<em>The wood center supports removed and laid next to bilge for reference</em>
At this point I want to remove both the ledge and the center tabs as they don't seem to be structurally relevant. Right now they are just an obstruction for cleaning, painting, and wood removal.
<table style="width:auto;"><tr><td><a href="http://picasaweb.google.com/lh/photo/e8NDyfXu_0x1Iq07oHVm2lJr6DfRErIBmZXm78cdltk?feat=embedwebsite"><img src="http://lh3.ggpht.com/_d-5ZEBxjDiw/TL3s0kF7wxI/AAAAAAAASHY/v1c7NZ0xR-g/s400/IMG_20101019_120357.jpg" height="300" width="400" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="http://picasaweb.google.com/standardhuman/SoleProvider?authkey=Gv1sRgCKeI3Z6gwK_zfw&feat=embedwebsite">Sole Provider</a></td></tr></table>
<em>Note the ledge at the top of the photo and the center support tabs in bilge</em>
The ledge was over the edge of the plywood and so wasn't supporting it. When I lay the new floor, it seems I'll have to either lay the play on top of this ledge (thus raising the floor height somewhat, not good), or try to measure and wedge it up under there (seems like a poor plan for easy future removal as well as for my sanity). I can't tell what the intended purpose of this ledge was...I would understand if the plywood was on top and the ledge supported the ply around the edges, but this is not the case. The ply rests on the hull under this ledge. On the other hand, it's pretty thick and well laid so it makes me think there may be a useful purpose I am overlooking.
Same goes for the center support-supports. Since I was able lift these wood support blocks up and out of the little fiberglass walls, they aren't really holding the floor down. The wood supports rest on the curvature of the hull and bilge anyway...so not really sure what the fiberglass tabs do other than keep the wood supports vertical and in place while installing the floor. If that's the case, I would rather cut and sand these fiberglass tabs off now. Later I can tack the supports together with a firing strip along the outsides if I need to secure them while laying the floor.
What do you all think? Get rid of these and get on with it? Or leave them and deal with them being a PITA?
One other strange thing: I was expecting to see keel bolt, but see none.
Photo album of project with more detailed images.
Many thanks,
Brian
Many thanks,
Brian
