I was curious if anyone has thought about installing solid cockpit drains in their Ericson, in particular a 32-2. I am told it is a common practice on boats built in NZ.
They could be built using a cardboard tube as a mandral building the fiberglass up to any thickness, say 3/8" thick and installed in place of the current hose and gate valve, a straight shot from the cockpit to the hull. A similar short section of tube could tie the aft cockpit in to the forward cockpit.
Advantages would be that the drains would be as strong or stronger then the surrounding fiberglass and become a structural part of the boat. A second advantage would be no hose or gate valve to fail when one is away from the boat. If they did fail, a wooden bung could plug that hole as if it were a failed seacock.
I would like to hear all opinions, pros and cons.
Thanks much,
Clay
Thanks much,
Clay
