Spreader base bracket for E27 HELP!
ShelleyG
HI, everyone. I am in need of a spreader base bracket, (Port side) broke mine a couple days ago while climbing to install a windex.
So far i have had no luck in finding this piece anywhere, places i have called are pacific seacfraft, RigRight, LeFiell manufacturing.
Any help or sugestions would be greatly appreciated.
Thanks and in advanced.
Michelle
E27 Cloud Croft
Boston, MA
rssailor
Spreader bracket
You might want to contact seth on this site as he used to work for ericson and might be able to help you. Otherwise find a good marine metal shop and have them duplicate the old one twice as if one broke the other can't be far behind. I had to have mine rewelded as one cracked, but mine are stainless and yours are aluminum. Ryan
mdgann
'76 E23
spreader base
Two years ago I had the same experience with my E23. I am told that they used the same mast extrusion for E23, E25 and the E27. I searched high and low for about 6 months trying to find a replacement. Many suggested that I go with a round tube set of new spreaders. I like the airfoil shaped ones too much. I have given up and fabricated a starboard spreader base out of steel and have been using it ever since. I have also contemplated casting my own using the old one glued together for a pattern. If you have any luck finding a source, I would really like to hear about it. If I ever am successful in casting one, I will post it here. Good luck in your search.
