Non Ericson specific.
I have a friend with a Catalina 30 with a starter problem. Turning the key to start the diesel the engine would crank and start but the starter would not disengage. If you turned the key to the off position the starter would stop and the engine would run fine. My friend replaced the starter/solenoid and nothing changed (starter kept running until key was turned off). He replaced the switch and now the engine starts, the starter keeps cranking but when the key is turned off the engine stops.
Any thoughts?
Any thoughts?
